Author Topic: Branching on sequence diagram  (Read 6375 times)
MattD
« on: April 28, 2002, 02:58:42 pm »
Great to see branching on the sequence diagrams.
I have managed to create a branch by right clicking on the message below the main one, but I cannot do this all the time.
Does anyone know the correct EA conditions that allow me to create a message branch consistently?
Matt
mch
Re: Branching on sequence diagram
« Reply #1 on: April 30, 2002, 03:22:37 pm »
Branching is showing some interesting behaviour.
  • When I add a couple of objects and messages to a sequence diagram the branching option is not available. I save the diagram and still no branching option. Switch to another diagram and back and the branching option is there!
  • Add another object and a couple of message, no branching option available. Save and switch out/back and branching is available.
  • Add a couple of messages beneath an existing branch, select the branch option on the lower message and it branches from the existing branch structure!
    Save, switch out/back, and the branch appears correctly
Cheers,
Mark
gsparks
  • I love YaBB 1 Gold!
« Reply #2 on: May 02, 2002, 04:37:38 am »
Hi Matt,
Ill check this out. We have an update coming out early next week - so if there is something amiss Ill get it fixed by then. Sounds like something not intitialising properly under some curcumstances.
Cheers,
Geoff Sparks
ronnie
« Reply #3 on: May 02, 2002, 03:42:09 pm »
Until there is a fix, you don't have to switch to another diagram, just make sure auto-save is on and double click in the project explorer on the diagram you are editing.
Nothing happens on the screen, but the menu options miraculously appear.
Ronnie
Ronnie
gsparks
« Reply #4 on: May 05, 2002, 05:35:42 pm »
Hi guys,
Just an update. I have tracked down the initialisation problem and it is fixed for the next minor update. This is now due out tomorrow - and will be build 487 or higher.
Cheers,
Geoff Sparks
