Author Topic: Code generator addin  (Read 3617 times)
Rogier van Stapele
« on: November 23, 2006, 05:05:30 am »
I developed a code generator addin for the PLC language IEC61131-3.
My addin works fine but I can't find the answers to some questions:
Where can I set the extension of the source files that are created? All files have the extension ".h" from Java although I set the default language to my new language.
Where can I find the Multiplicity in a connector's end?
What is the functional difference between an ElementId and an ElementGuid?
Jsc
Re: Code generator addin
« Reply #1 on: January 21, 2020, 07:28:28 pm »
the first question can be solved by using the MDG Technology. So you can define the .xml as the standard generated file extension.
Otherweise i have also written two templates for the code generation to PLC:
the first ist .xml File for PLCopen; the second ist .xml File in .Zip which are specific for TwinCAT
Are you still working in this object. i am glad to dicuss this thema further.
« Reply #2 on: January 21, 2020, 08:03:51 pm »
2. t_connector.sourceCard / destCard
3. ID is only local in your database. A fast integer as primary index. GUIDs are preserved over model transfers. Slower search but valid in any model.
