Author Topic: bug on RTF Template and the Scenarios on a Usecase  (Read 3587 times)
stepheny
  • I love YaBB 1 Gold!
« on: June 04, 2002, 02:29:55 am »
Hi all,
 On the lastest build, just trying out the RTF template, if you modified some of the items in there (like Attribute Heading) and clear everything in the textbox, when u click "save" it will display a error stated that "Template has no content". It's kind of strange because some of the default one (Attribute Heading and Attribute Line Item) default has no content at all.
 Another bug is at the Scenarios tag at a UseCase, if you just input the Scenarios name but didn't type any content at the textbox below, when you click ok, it will ask you whether you want to save or not, click save and a error will pop up: "Field 't_objectscenarios.Notes' cannot be a zero-length string." It's not really a serious bug... but just happen to notice it.
 BTW, you guys make a great product, keep up the good work.
-Stephen Yau
gsparks
Re: bug on RTF Template and the Scenarios on a Use
« Reply #1 on: June 04, 2002, 06:28:12 pm »
EA requires some content in the RTF templates - so an empty template is considered an error - and you are notified when this condition occurs.
I checked out the two you mention as having no content and discovered they were inadvertent duplicates of the two equivalent items at the head of the list - so I have removed those items from the list of RTF templates. Sorry for the confusion.
I will check out the Scenario problem ... thanks for the information.
Cheers,
Geoff Sparks
