Author Topic: Bug: 'Debug Window' when adding attribute to class  (Read 3903 times)
Bebe Stanie
« on: June 13, 2002, 12:13:44 am »
We have encountered the following problem (see test case below) in at least builds 493 and 494:
- Create new project
- Add new class
- Add first attribute:
The project browser does NOT show the attribute
- Add second attribute:
The project browser does NOT show either of the attributes
- Move the mouse pointer over the class in the project browser:
ONLY the FIRST attribute is shown (if clicked on the '+' to fold out tree) (also a small 'update view' bug here)
- Click on attribute:
The following message shows in the attribute window:
  "DBG: End of set att <name of attribute>"  ???
- Swap order of attributes in the attribute window:
The project browser suddenly shows both attributes.
Hope you can reproduce this behaviour, and can find a solution.
B.S.
gsparks
  • I love YaBB 1 Gold!
Re: Bug: 'Debug Window' when adding attribute to c
« Reply #1 on: June 13, 2002, 04:29:17 am »
Firstly - the message box has been removed for the next build - my apologies for the error.
Secondly - I tested out the sequence you suggest and it appears that for a tree node that has been freshly added, there is some drawing quirk that stops the + symbol being drawn. If you move the mouse over the node after adding one attribute, it appears and is functional.
I will check this out - it is a strange one.
Thanks for the report - build 495 will get rid of the message (it should be out later tonite)
Geoff Sparks
