Author Topic: Bug (small): Strange Package behaviour  (Read 3891 times)
Bebe Stanie
« on: June 13, 2002, 07:25:07 am »
We have encountered yet another strange behaviour (a.k.a. 'bug') (see test case below) in build 494:
- Create new project
- Go to a node in the tree, and click right and select 'Add New Package Here'.
- Call this package 'First Test' and set note (see properties) to 'First Test' as well.
- Go to the same node in the tree, and click right and select 'New Element'.
- Select 'Package' and call it 'Second Test' and set note to 'Second Test'.
And then the 'First Test' has automagically ;D been renamed to 'Second Test' (see note, it's indeed the first one).
Good luck, and keep up the good work.
B.S.
