Author Topic: Java Debugging Problem  (Read 3225 times)
swidjaja
« on: December 05, 2006, 11:45:06 am »
Hi all.
I have EA Corporate Edition (v 6.5.799).  I have been trying to run debugging in order to auto-generate a sequence diagram (on a very simple class) and have not been able to get it to work.
Basically after I select the option "Build and Run --> Debug Run", I will see:
- a MS window console with titled "C:\Program Files\Sparx Systems\EA\SSProfiler65.exe" started, but ended within the next 10 secs
- The EA's Debug Bench will have the following output:
05/12/2006 14::40 Loading Java Virtual Machine from path C:\Program Files\Java\j2re1.4.2_13\bin\client\jvm.dll
05/12/2006 14::40 Obtained Java Virtual Machine version 1.4
And then it stops.  My class' main has a simple System.out.println() - which is marked as breakpoint.  The output was never shown.
I followed the video tutorial (from Sparx) step by step.
Any idea?
Thanks in advance
- Sam
