Author Topic: revision control  (Read 2903 times)
Molto Mike
revision control
« on: July 03, 2002, 03:39:28 pm »
EA provides revision control through replication and controlled packages/XML per package.
Wouldn't XML export/import of the project root do the job for the whole model?
In other words: If I export am model's project root (normally called "Views"), and reimport it, will the project be exactly the same or would I be missing anything?
I suspect there is a reason why the docs speak about XML based versioning only on a package level?
TIA,
Mike
