Author Topic: Request: Use HyperLink as Activity "Object Type"  (Read 4424 times)
CJ
« on: July 11, 2002, 08:11:21 am »
G'day folks,
I've got a pretty big activity diagram that I've broken down into chunks.
Instead of having, say, an activity object called "Sub-Process B", I put a hyperlink to "Sub-Process B" in my main activity diagram, and use the hyperlink in the diagram the same as any Activity Object.
EA (3.10 Build 496) won't let me draw a flow line to/from a hyperlink, saying "The requested connection is not UML compliant".  Could EA be allowed to do this?
As a work-around, I've created an activity object called "Sub-Process B" in my main activity diagram and create flows to/from this.  EA then allows me to "Set Source and Target..." for flows, changing the original source/target to the hyperlink, no problem.  Is this a bad idea?
Much appreciated.
Cheers and best regards.
gsparks
  • I love YaBB 1 Gold!
Re: Request: Use HyperLink as Activity "Object Typ
« Reply #1 on: July 12, 2002, 05:29:51 am »
You could try the following - it looks OK, conveys the same meaning and  wont cause headaches ...
When Activity A has a transition to Activity B in another diagram, have Activity B in both diagrams (just drag B from the browser onto the diagram with A). Connect the two with a transition (flow). Then create a hyperlink element to the second diagram ... enlarge it to be bigger than the activity B, use the fill color to make it stand out a bit and Z-order it to the bottom.
Now you have correct syntax and a convenient 'hyperlink' pad to the next part of the story. If you include A in B's diagram you also have a jump back.
Cheers,
Geoff Sparks
CJ
« Reply #2 on: July 12, 2002, 09:44:24 am »
Thanks Geoff,
Doesn't look to shabby at all.
Much appreciated.
