Author Topic: Database datatypes: sql server 2000 support  (Read 3362 times)
raymondsing
« on: July 24, 2002, 08:21:22 pm »
Hi everyone,
1) Does anyone know whether the datatypes in sql server 7 and 2000 are the same? If not, would u like to have support for 2000?
2) If I want to reverse engineer from an existing database, does it make a difference whether i select the database datatypes before and after importing?
cheers!
Ilia
Re: Database datatypes: sql server 2000 support
« Reply #1 on: July 25, 2002, 11:29:03 am »
Hi
"SQL Server 2000 introduces three new data types. bigint is an 8-byte integer type. sql_variant is a type that allows the storage of data values of different data types. table is a type that allows applications to store results temporarily for later use."
You can define new data types for sql server 2000 in Reference \ Database Datatypes if you like.
