Author Topic: Help me out  (Read 5383 times)
rubanr
  • I love YaBB 1 Gold!
Help me out
« on: July 29, 2002, 05:42:07 am »
i  have just downloaded EA Version 3.10 - Build 500 . When  i try  to  open a new project or open one i get a  message that ea has made a illegal operation  :'(
I use Win98 SE .This  is  the dump i get . help me  out
EA caused an invalid page fault in
module EA.EXE at 017f:0045dddc.
Registers:
EAX=00000000 CS=017f EIP=0045dddc EFLGS=00010206
EBX=00000000 SS=0187 ESP=00ade6a4 EBP=00aded7c
ECX=00c0bbe0 DS=0187 ESI=00c0bb70 FS=295f
EDX=0000000b ES=0187 EDI=00ade9d8 GS=0000
Bytes at CS:EIP:
81 38 1c 0d 00 00 75 1f e8 c1 e9 1e 00 8b 40 04
Stack dump:
7800b0a7 00ade9d8 00aded70 00ade6c0 00aded70 0045ddc0 00aded7c 00ade6e8 780090c3 0045ddc0 00aded70 00000100 00ade72c 780090d2 00726350 00aded70
« Last Edit: July 29, 2002, 06:20:28 am by rubanr »
runbarr
Re: Help me out
« Reply #1 on: July 29, 2002, 11:21:46 pm »
Try to uninstall, reinstall and update application again.
Best regards,
ro
ro
  • I wish I was good! Always look on bright side of l
Re: Help me out
« Reply #2 on: July 30, 2002, 01:46:24 am »
Welcome!
Change the operation system  :) :) :) :-[...
:D
Try to uninstall, reinstall and update application again. It should help You  ;).
Best regards,
ro
PS. If it doesn't finish successfully, try to reinstall system.
« Last Edit: July 30, 2002, 10:55:51 pm by ro »
raymondsing
Re: Help me out
« Reply #3 on: July 30, 2002, 10:38:43 am »
Hi, I believe u get this kind of error occassionally if ur system runs out of memory. I am not saying this is the reason, but that it might be.
raymondsing
Re: Help me out
« Reply #4 on: July 30, 2002, 10:41:34 am »
hi, I want to add that try closing all other applications before starting EA might help.
And by the way, Sparks was saying something about the new installer used in build 500? Don't know how that will affect win98 se.
rubanr
Re: Help me out
« Reply #5 on: July 30, 2002, 07:20:40 pm »
I tried closing all apps and reinstalling EA(which i did b4 posting this message).But the problem persists.All other applications are working fine .
But one interesting thing i like to add is that when i click the cancel button( to open EA without opening any file) EA starts up.but again the  same problem turns up if i try opening a  file.
I even downloaded EA again but in vain.
« Last Edit: July 30, 2002, 07:30:12 pm by rubanr »
sparks
Re: Help me out
« Reply #6 on: August 02, 2002, 06:16:46 am »
To answer your easier question first, EA is behaving as design after you press cancel (on the open a project screen).  The ability to do this is required to perform admin functions to project files.
To the problem at hand.  Is this your first install of EA?  Do you have MSAccess 2000 (or later) installed on your machine?  At the moment we are not sure what could be causing the problem.  It could be a MSJet problem since you you are only receiving after you select a project to open.  In the past we have had one or two reported problems related to corrupted registry entries that caused simliar problems.
Maybe you could send us an email to either [email protected]  or [email protected] with the answers to the above questions or any other additional information you can think of.  We will be able to continue this discussion in a faster manner.
Paul Mathers
