Author Topic: Constraint tab  (Read 4227 times)
EA_Nj
Constraint tab
« on: August 07, 2002, 03:53:48 pm »
I want to use the constraint tab of Use Case properties to specify my pre and post conditions.  However I want all of my preconditions to appear one below the other and all of the post condition to appear after the preconditions.  However there is no control that I have on the order in which these appear in the rtf document.
I am currently doing a project and would urgently want some functionality by which I could move certain constraints up and down (just as class attributes can be manipulated with the up and down hand icons).
Is there a way that you can put this change in so that I can create all of my pre and post conditions through the constraints tab?
Thanks!
Jamal
gsparks
  • I love YaBB 1 Gold!
Re: Constraint tab
« Reply #1 on: August 08, 2002, 03:48:54 am »
Hi Jamal,
Ive had a quick look and Ill put the change in for the next build, which will be out in a few days time. We are releasing build 501 tonite, but there will probably be a maintenance release over the weekend or early next week to catch up with a few other issues. Look for build 502 or higher.
Geoff Sparks
EA_Nj
Re: Constraint tab
« Reply #2 on: August 08, 2002, 06:53:28 am »
Thanks for following up.  Ok, that sounds good. If the functionality will be available by Monday then I'll start planning my use case descriptions around that.
I think that will enhance and expedite the usability of the product during this critical stage.
Any plans of making the product compatible with UML 1.4?
Thanks.
