Author Topic: Routed Line as default line drawing mechanism  (Read 3411 times)
EA_Nj
« on: August 08, 2002, 08:30:42 am »
I am spending unnecessary time changing the properties of my lines in Use Case Diagrams and Domain Analysis Diagrams so that all of the lines appear as routed lines.
I checked the Diagram Options dialog but didn't find anything for line styles.  Could you please add something in the options dialog that will make the tool generate routed lines without me having to modify their properties manually?
Thanks.
Jamal
gsparks
  • I love YaBB 1 Gold!
Re: Routed Line as default line drawing mechanism
« Reply #1 on: August 08, 2002, 05:00:16 pm »
The option is on the View/Options/Object page - a drop list on the right hand side. You can select Direct, Routed or Custom as the default style for new connections between objects.
Cheers,
Geoff Sparks
