Author Topic: Reverse Engineering Notification  (Read 3758 times)
Chris Rajczi
« on: August 15, 2002, 12:48:35 pm »
I am sorry for asking what may be a simple question, but I am new to using EA.
How can I as the architect be notified if a developer has changed an object or method.  Right now, all I can find is to reverse the source files back into the diagram and the search for what has been changed.  Is there so setting that I can put on the class that says "notify if source changed?"
Chris
sparks
Re: Reverse Engineering Notification
« Reply #1 on: August 17, 2002, 06:20:22 am »
EA does not store the date that last time a object was generated and it does not have any facilities to notify people, however you can bring up the Find Object screen and search for any object modified after a particular date.  This way is not dependant on someone else physically generating the source code again.  Hope this helps.
Paul Mathers
