Author Topic: Sequence messages  (Read 4161 times)
Jara
Sequence messages
« on: August 21, 2002, 12:18:43 am »
I have two questions about sequence diagram in EA v.3.1.0. build 489.
1. Any sequence message has in properties field "Notes".
     This field can't view and edit in common "Properties workspace" (as for e.g. class note).
     Is it possible?
2. When I create new sequence message, in message properties can I select
     existing method. OK. But - automatically with parameters ...
     It is sometimes discomfort.
     In diagram is possible prevent it with mode "Operation parameters: None".
     But for RTF document?
     How can I create RTF document without parameters in "Message" column?
Thanks for answer.
Jara
ronnie
Re: Sequence messages
« Reply #1 on: August 21, 2002, 02:11:04 pm »
The comment regarding picking operations out of the destination object on a sequence diagram is a good one - I recently had a UML course with work (unfortunately on a different product - more expensive and not so good) and they did the same!
Ronnie
jaimeglz
« Reply #2 on: August 23, 2002, 08:33:59 am »
Can you clafify the issue? I use sequence diagrams a lot, but I'm missing what is being discussed here. Thanks in advance.
Jaime Gonzalez
