Author Topic: Q: not able to resize synch bar with mouse  (Read 4445 times)
rolf
« on: August 23, 2002, 09:21:51 am »
does someone know how to increase the size of a synchronization bar in an activity diagram? I'm able to select the bar and to move it with the mouse, but resizing is impossible.
  I've been successful
- defining an activity
- making it as wide as the sync bar should be
- selecting both
- and executing  "Diagram -> Make same -> width".
But I doubt that it's the  only way.
Thanks in advance
Rolf
sparks
Re: Q: not able to resize synch bar with mouse
« Reply #1 on: August 27, 2002, 06:25:43 am »
I have just tried to resize a synch bar and was able to successfully do it, using the following procedure.  Select the bar (so that it is highlighted) then click and drag on one of the corner squares (that is shown once the object to selected) to the desired size.  You can also use the Ctrl + Arrow Keys to resize the object.
Hope this helps.
Paul Mathers
« Last Edit: August 27, 2002, 06:26:29 am by sparks »
rolf
« Reply #2 on: August 27, 2002, 07:12:48 am »
Oh really - it works!
I always tried if the arrows have been visible.
Rolf
