Author Topic: Problem with Reverse engineer VB modules  (Read 4006 times)
raymondsing
« on: August 28, 2002, 04:27:46 am »
hi,
Any idea why module files (.bas) are not reverse engineered?
I right-click on Logical Model, select Code Engineering -> import source directory.
All the forms (.frm) are reverse engineered, but not module files.
I am using EA3.1 build 501.
« Last Edit: August 28, 2002, 04:28:43 am by raymondsing »
gsparks
  • I love YaBB 1 Gold!
Re: Problem with Reverse engineer VB modules
« Reply #1 on: August 29, 2002, 04:44:55 am »
If you check out the View/Options/Code Generation/Visual Basic dialog, there is an edit box to enter the default extensions to be processed when importing VB. Add .bas to the list.
Hope this helps,
Geoff Sparks
raymondsing
« Reply #2 on: August 30, 2002, 02:37:15 am »
hi,
Oh I see! Thanks, I'll go and try. ;D
