Author Topic: C++ array attributes  (Read 4063 times)
mbc
  • Embedded software developer
« on: August 29, 2002, 02:01:23 am »
What is the best way to define class attributes which should translate to arrays in the generated C++ code? I have tried reverse engineering some C++ code, and then generated the code (in a new file), but this generates
   char [ARRAY_SIZE] MyArray;
instead of
   char MyArray[ARRAY_SIZE];
mbc
Re: C++ array attributes
« Reply #1 on: September 06, 2002, 07:18:55 am »
Just to expand a bit on my previous post:
I guess that this is probably just a bug (or missing feature;)), because noone has replied.
What about the "Multiplicity" settings for an attribute? As far as I can tell, they have no effect on C++ code generation. Why not use these to specify an array?
Mikkel
