Author Topic: ORA-01000: Maximum open cursors exceeded  (Read 3944 times)
CJ
« on: September 10, 2002, 10:42:01 am »
G'day folks,
When I try to reverse engineer our database (about 180 tables), I get the ORA-01000 repeatedly (I don't know how many times) ... I just hold down the enter key until the message box doesn't show up anymore, and the process seems to be done.
I talked with the DBA, and Oracle is set to allow up to 500 cursors per session.  Is there something I haven't setup correctly for the ODBC data source?  Or, is there some bug in EA?
Finally, if it is a bug in EA, does it have any negative impact on the reverse engineering process, other than repeating the ORA-01000 message over and over again?
Much appreciated and best regards.
Cheers and best regards.
CJ
status update
« Reply #1 on: September 11, 2002, 05:11:50 am »
G'day folks,
Got the DBA to double the max number of cursors per session to 1000, and no more problems.
Is there a guideline as to the max number of cursors per session required to reverse engineer a data model?  Is the number of cursors related somehow to the number of tables being imported?
