Author Topic: Drawing bug: Custom Line Nodes  (Read 4475 times)
crispan
  • The sun is going down ...
« on: September 12, 2002, 12:03:44 pm »
I am using ED V3.11 Build 503.
When I use custom lines with additional nodes (which were created with "Toggle line point at cursor") in super state or super activity diagramms and then move the super state or super activity diagramm the additional nodes (and only them) stay on a fix position.
So their position is relative to the origin of the diagram but not as it should be relative to the origin of the super state diagram.
Any hints when this will be "fixed"? ;-)
Crispan
sparks
Re: Drawing bug: Custom Line Nodes
« Reply #1 on: September 13, 2002, 05:03:12 am »
We have had a look at this issue and it appears that when a link is positioned in a 'container' and the container is moved the link points are not moved correctly.  We have had the same problem reported about boundary objects, so we are going to look into this problem ASAP.  At the moment the only workaround is to select all objects using the mouse 'rubber banding' - then move.
Paul Mathers
crispan
« Reply #2 on: September 13, 2002, 07:40:47 am »
Thanks for the hint and the fixing information.
Cheers,
Crispan  :D
