Author Topic: Getting the Basic Add-in to work /be visible in EA  (Read 4137 times)
newbie
« on: January 04, 2007, 01:28:45 pm »
I'm using a Trial version of EA 6.5 and I have tried to create a Basic Add-In for EA as given as an example in
http://www.sparxsystems.com.au/bin/CS_AddinFramework.zip
I have followed the steps mentioned in the readme.txt and
- I'm able to compile my project without any errors and warnings,
- I have registered the registry key using regasm (this is NOT mentioned in the readme.txt
- When I hit F5 within Microsoft Visual C# 2005 Express Edition with EA closed, EA is launched, but I don't see the Add-In in the Add-Ins.
What am I doing wrong or doesn't the trial version of EA support add-ins?  ???
« Last Edit: January 04, 2007, 01:32:10 pm by newbie »
Re: Getting the Basic Add-in to work /be visible i
« Reply #1 on: January 04, 2007, 03:14:47 pm »
First thing to try if the Add-In menu doesn't show is to reset your menu: Tools | Customize | Menu | Reset.
« Reply #2 on: January 04, 2007, 03:16:04 pm »
newbie
« Reply #3 on: January 08, 2007, 07:52:45 am »
This was really a newbie RTFM mistake :-[Apparently I should NOT have used the registry entry HKEY_CURRENT_USER\Software\Sparkx Systems\EA400\EA\AddIns (which seems logical as it is created during installation). But to use the location as indicated in the readme.txt HKEY_CURRENT_USER\Software\Sparx Systems\EAAddins\CS_AddinFramework
I'm now able to see the Add-in but hope not to come across the problem mentioned in http://www.sparxsystems.com.au/cgi-bin/yabb/YaBB.pl?board=Automation;action=display;num=1125541266;start=1#1 by vanWeyden and thomaskilian.
Have you added the addin to the registy?
See http://www.sparxsystems.com/EAUserGuide/index.html?deployingaddins.htm
