Author Topic: Activity diagrams - sub diagram capability?  (Read 6196 times)
Royski
  • I love YaBB 1 Gold!
« on: September 25, 2002, 06:50:52 am »
UML permits several activities, states, decsion blocks and objects to be connected up as a general work flow and to be bundled up as a sub-diagram, which can then be used as a single activity in other diagrams. Does EA permit this? I've looked in the help section but I can't see how; and I've tried experimenting but failed to find a way.
CJ
Re: Activity diagrams - sub diagram capability?
« Reply #1 on: September 25, 2002, 07:40:17 am »
G'day Royski,
There may be other ways, but here is how I've setup sub-diagrams for activity diagrams.  If there is a standard UML way of doing it, I'd sure like to know...
1) Draw the "main" activity diagram in some package, using only the activity diagram objects;
2) Draw the "sub" activity diagram in some other package;
3) From the browser, copy the "sub" activity diagram (i.e. create a diagram link) into the "main" activity diagram.
4) Setup some kind of visual cue that a particular activity in your "main" activity diagram has sub-activities in the diagram link created in 3).
The visual cue I've setup, for an activity that has sub-activities, is to give the activity a stand-out colour, and to move the sub-activity diagram link right in the activity object.  (I've setup the link's properties so that it has not text).
If you want a sample, send me an e-mail.  I've got a couple diagrams saved to .gif
Best regards.
Cheers and best regards.
Royski
« Reply #2 on: September 25, 2002, 11:59:08 am »
thanks Jason, still not sure though. I can drag the "sub" onto the "main" but I can only do this once, which defeats the object as I want to use it in several places in the "main". I think you are suggesting that I create an activity in the "main" and create an association link to the "sub"; am I right? This works but is not intuitive, and the reader would find it unwieldy to trace back to the "sub". Can you confirm if I'm interpreting you correctly? Thanks once again.
PhilR
« Reply #3 on: September 25, 2002, 07:35:16 pm »
UML 1.4 has a stereotype icon to indicate that an activity is decomposed into a sub-activity diagram.  The logical way for a tool vendor to implement this would be to "double click" on the master activity which woiuld launch the sub-activity diagram.  EA of course does not implement this.
It also makes sense to "double click" on a class and launch a State Chart which decsribes the class life-cycle.  Again EA does not implement this.
Generally the OO community rather shys away from this approach because it smacks of funcitonal decomposition a bit.
By the way Rose (and other tools) implement all sorts of fussy rules about what can decompose into what.  No thanks.
Phil.
