Author Topic: How to recover from EAP file integrity problem  (Read 4540 times)
hynek
  • Trying to use EA in team software developement
« on: August 29, 2002, 08:02:44 am »
We use EA in the team software developement and are concurrently accessing the EAP file on our file server. Recently, as the project grows, we face the problem of frequent data corruption events (invalid database format, no current record and other EA/Jet engine error messages). If this happens, I try to do Repair on the file, but even if the repair succeeds (not always), some data (objects) is lost. The problem is probably in our network/file server but is there anybody else with such an experience ?
Thanks for Your advice
Hynek
sparks
Re: How to recover from EAP file integrity problem
« Reply #1 on: September 04, 2002, 06:34:14 am »
Yes their are other users that experience the same problem and usually the problem is caused by a slow or poor performing file server.   Probably the easiest thing to do (assuming you have one) is to move the EAP file to a more efficient file server.
You might also want to review the following articles to see if the suggestions
provided will help:
Q306204 ACC2000: How to Troubleshoot Corruption in an Access Database
http://support.microsoft.com/support/kb/articles/q306/2/04.asp
Q300216 ACC2000: How to Minimize Database Corruption When Using Jet 4.0
http://support.microsoft.com/support/kb/articles/q300/2/16.asp
Q209137 ACC2000: How to Troubleshoot/Repair a Damaged Jet 4.0 Database
http://support.microsoft.com/support/kb/articles/q209/1/37.asp
Q304561 ACC2000: Using MS Query to Recover Data from a Damaged Database
http://support.microsoft.com/support/kb/articles/q304/5/61.asp
Paul Mathers
« Last Edit: September 06, 2002, 07:32:18 am by sparks »
Santiago Reyes
« Reply #2 on: October 07, 2002, 11:41:31 am »
Hi, we also have the same problem with jet engine messages.  Did you manage how to solve the problem ?
hynek
« Reply #3 on: October 08, 2002, 02:39:59 am »
...not yet, unfortunately (time reason :).
Also, we have encountered similar problems with our Microsoft SourceSafe database files (CRC checksum errors)...
There is a thread related to the same problem, see http://www.sparxsystems.com.au/cgi-bin/yabb/YaBB.cgi?board=general&action=display&num=1033570412
Hynek
