Author Topic: Error importing Automation XML model file  (Read 4364 times)
Rafael Gonzalez
  • I love YaBB 1 Gold!
« on: September 19, 2002, 05:20:25 am »
Hi all:
I'm trying to import the Automation model published by Spark Systems into my EA (b504) but it shows a lot of errors.
Here is what I'm doing. Can anyone help me ?
Thank you very much
Rafael
1) Create a new project called test.eap from EABase.eap
2) Goto the Views Incon in the workspace panel (it is supposed to be the current model)
3) Click right and select "Import model form XML"
4) Select the "Automation XML.xml" file from my folders and leave the deault options set.
5) Click "Import"
Then some error mesagges boxes appear
* The first one "Data type conversion error"
* The second "You can't add or change a record because a related record is required in table t_package" shows 8 or 9 times
* Finally shows "ERROR: could not find package to insert diagram into"
The workspace view shows 8 more models or projects, all empty:
"Code Examples"
"Connector"
"Diagram"
"Element"
"ElementFeatures"
"Overview"
"Project Interface"
"Repository"
Darren Lock
Re: Error importing Automation XML model file
« Reply #1 on: October 11, 2002, 01:36:04 am »
Rafael,
where did you find the the XML file ???
Darren Lock
United Kingdom
mbc
  • Embedded software developer
« Reply #2 on: October 14, 2002, 05:49:14 am »
Darren,
from the "Download Section" on the Registered Users' pages.
Mikkel
