Author Topic: Running ant from "package build script"  (Read 3275 times)
michaelp51
« on: January 11, 2007, 01:54:03 pm »
I've recently started learning EA (6.5, latest build). I have a working web service that I'd like to build using EA and ant. So far I've tried many variants in the build setup, but all I get is return code 101, nothing built...
Usually, I just go to the root directory, add some classpaths and type ant.
Anyone tried this successfully in EA?
Re: Running ant from "package build script&qu
« Reply #1 on: January 11, 2007, 02:03:34 pm »
I've done it.  From memory there wasn't anything special required.
The best recommendation that I have is to try adding the classpaths you mentioned into the environment variable for windows and then re-try it.
