Author Topic: Corporate Edition  (Read 5568 times)
iain
Corporate Edition
« on: October 16, 2002, 06:08:32 am »
The 'Corporate Edition' is mentioned throughout version 3.5 can you tell me what the pricing model is for this and also whether support for Oracle repository is available
kelly_sumrall
Re: Corporate Edition
« Reply #1 on: October 16, 2002, 09:18:17 am »
I think the Corporate Edition will be $20.00 USD more than the Professional version.  As far as Oracle, I'm sure it will be available.
Kelly Sumrall
Even though curiosity killed the cat, it still had eight lives left.
Gary Wong
« Reply #2 on: October 17, 2002, 09:05:57 pm »
Actually, if you mean Oracle Repository (as in Designer CASE tool) then the answer is probably no.    The underlying metamodel in the Oracle Repository is quite complex and it would be a huge undertaking for EA to 'talk with' the Repository.
Gary
Marek Brezina
« Reply #3 on: October 22, 2002, 01:50:06 am »
I have problem with creating database for EA. When creating tables an error message appears:
Warning! The maximum key length is 900 bytes. The index 'aaaaat_objectproblems_PK' has maximum length of 1024 bytes. For some combination of large values, the insert/update operation will fail.
Thanks Marek
Marek Brezina
« Reply #4 on: October 23, 2002, 04:41:40 am »
I solved the problem, I changed type nvarchar on varchar, but another appeared when imported model from xml, "Operand type clash: int is incompatible with ntext"
gsparks
  • I love YaBB 1 Gold!
« Reply #5 on: October 28, 2002, 04:14:11 am »
Hi All,
The Corporate Edition is being released shortly and will sell for 179$ per license as opposed to 149$ for the Professional, a difference of 30$. The Coporate Edition will connect to a MySQL or a SQL Server based repository. Support for Oracle, DB2 and PostgreSQL is planned.
We will offer a 20$ Professional to Corporate upgrade for the month of November to allow existing users a chance to upgrade at a discount.
The issues regarding the error messages on creating SQL Server tables has been resolved as has the "Operand type clash" issue...thanks for the feedback on these Marek.
Geoff Sparks
