Author Topic: Version 4.00 - Beta Build 2 Released (Reg Users)  (Read 21662 times)
sparks
« on: February 23, 2004, 07:32:32 pm »
Release Notes for EA 4.00 Build 716 (Beta 02)
Added support for displaying and managing inherited and overridden tagged values.
Added support for displaying and managing inherited and overridden Ports and Parts values.
Added support for displaying inherited constraints.
Added support for displaying inherited responsibilities.
Added support for displaying inherited operations.
Added support for displaying inherited attributes.
Added support for over-riding initial values on Attributes within an inheritance hierarchy
Added Guard and Weight settings to ControlFlow property dialog
Added <<hyperlink>> as a valid GUIElement stereotype (behaves like text hyperlink element)
Added support for named message endpoints and diagram gates
Modifications to Foreign Key dialog
Additional support for defining UML Profiles using UML 2.0 Profile notation
UML Profile Toolbox compartment added
DDL Generation - fixed default comment tag when none selected.
Foreign keys - fixed corruption of FK information when changing name of non-FK operaton.
Corrected error in object search when Scenarios, Tags, etc checked.
Corrected display and updating of Diagram Note Created and Updated dates.
Updated C++ code engineering to support type-definitions of the form: typedef struct foo {...} bar;
Fixed integrity checking bug where there are orphaned requirements.
Fixed saving object efforts, risks and metrics where Notes is empty string.
Fixed bug in synchronization of foreign keys during DDL ODBC import.
Added tidy shutdown if network connection broken.
Fixed missing DB2 Data Type display in table attributes dialog.
Fixed creation of duplicate issues on Oracle repository when closing issue and selecting OK on dialog.
Added check when opening project with incorrect connect string to avoid network error message.
Added check for valid filename when generating individual DDL scripts from Project View.
Altered order of messages on completion of Data Transfer of model.
Added 3 GUIDCols missing from GetGUIDCol function in Data Transfer.
Changed source and target database connect string fields on Data Transfer dialog to read only.
Altered PostgreSQL datatype details when importing PostgreSQL tables through ODBC.
Added option to reset GUIDs when createing a new model.
Added support for PostgreSQL repository.
Added ability to create foreign keys referencing unique columns as well as primary key columns.
Bug fixes.
