Author Topic: C++ code generation  (Read 3447 times)
onlineBusSyst
C++ code generation
« on: November 20, 2002, 04:25:23 pm »
Newbie question; How do you go about getting implementaion code into the generated output? For example, when I define an operation in a class in the logical view, and then try to add method code in behavior, the code gets generated in commented out fashion, such as;
//cout<<"this was written in the behavior of the operation\n";
so I can't go from generate to compile to run without manually altering the generated code.
Also, how would you go about doing something like;
#define TITLE "test.cpp\n"
onlineBusSyst
Re: C++ code generation_INVALID USER ID
« Reply #1 on: November 20, 2002, 07:42:24 pm »
Who ever is using my user ID please use your own.  Thanks
gary
« Reply #2 on: November 21, 2002, 09:50:23 am »
That is the ID EA gave me. Must be a default ID.
onlineBusSyst
« Reply #3 on: November 26, 2002, 06:32:17 am »
This is the id given to me too. I sent an email to the support.  ???
