Author Topic: Adding a number of identical associations  (Read 3243 times)
DaveWoodward
« on: November 28, 2002, 06:52:17 am »
should be a simple one I think. Add 10 use cases to a diagram along with one actor. The actor can perform all the use cases, so add a uses association for each use case.
1. Click on uses association in object menu
2. click on source in diagram view and drag to target
3. repeat from 1 for each use case.
I'd really like to avoid having to click on the object menu each time. Can I 'lock' the uses association so i can just keep dragging until I want to stop?
Also, what is the 'Create a new relationship' icon in the tool bar for? Doesn't seem to do much of anything!
Cheers
Takeshi_KOUNO
Re: Adding a number of identical associations
« Reply #1 on: December 01, 2002, 06:54:28 pm »
I recommend you to use 'F3' key.
1. make uses association
2. push 'F3' key
3. drag from source to target
4. repeat 2. and 3. until you finish
It's better way,so please try.
Takeshi KOUNO
