Author Topic: Importing from Rose  (Read 4382 times)
Stephen
Importing from Rose
« on: December 05, 2002, 02:13:41 am »
Hi All,
I am evaluating the corporate edition of EA and I need to import our current Rose model into a EA project stored in a SQL Server 2000 database.  I ran the script to create the database and it worked fine.  I can add, edit etc. everything from within the EA environment.
I export the Rose model using the Unisys plug in. When I try and do the import I get the following error "Microsoft OLE DB provider for SQL Server [-2147217900] Incorrect syntax near the keyword "User".
Am I doing something wrong?
Stephen
Stephen
Re: Importing from Rose
« Reply #1 on: December 05, 2002, 02:27:29 am »
Ok I dropped the database, created a new one and ran the script again.  Then I created a new EA project, transferred the empty project to the SQL server database and ran the import again.
This time it got a lot further through the import but then crashed with the following error:
"Microsoft cursor engine [-2147467259] Data provider or other service returned an E_FAIL status"
Any ideas?
gsparks
  • I love YaBB 1 Gold!
« Reply #2 on: December 07, 2002, 02:31:43 am »
If you can send me a zipped up copy of the XMI, I will track down the problem and correct any errors as soon as possible.
You can email me at:
[email protected]  -or-
Geoff Sparks
