Author Topic: Automation Inteface : Geting Diagram Model Default  (Read 3981 times)
Diego_Croda
« on: January 22, 2007, 05:30:26 am »
How can i get de Diagram model default using automation interface via API?
Re: Automation Inteface : Geting Diagram Model Def
« Reply #1 on: January 22, 2007, 01:26:36 pm »
Not easily. Outside your add-in (in EA) you could define a custom search using the SQL Editor. Use this search:
select value from usys_system where property='Default Diagram'
and then run it from your add-in with Repository.RunModelSearch.  This will return a GUID which you can lookup with Repository.GetDiagramByGuid.
