Author Topic: Link note to message  (Read 3887 times)
Fintan
« on: January 15, 2003, 03:53:22 am »
Hi All,
I am having a problem linking a Note to a message on a sequence diagram.  No matter how hard I try I cannot get the link to connect from the Note to the message. :(
The only work around that I have found is to link the Note to the closest object and move the link end so that it looks like it is pointing to the message.
Any suggestions?
Many thanks,
Fintan
Mike Blake-Knox
Re: Link note to message
« Reply #1 on: January 15, 2003, 06:00:35 am »
It's not obvious, I spent time finding the answer to the same question yesterday. I don't know why trying to connect a note graphically doesn't work.
The easiest way I found was to create a new note (right click on the message, choose Attach Note or Constraint then hit OK on the Link Relations dialog). You can then paste your text into the Note.
Hope this helps.
Fintan
« Reply #2 on: January 15, 2003, 07:40:49 am »
Thanks Mike,
That worked a treat :D
Fintan
