Author Topic: Copying Operations and Attributes  (Read 4423 times)
Ian Turner
  • Crumbs Chief!
« on: January 23, 2003, 01:45:27 am »
Is there any way of copying an operation or attribute from one class to another?
I know you can move them using the Project Explorer but I haven't found a way to copy...
Cheers
Ian
wolfgang
Re: Copying Operations and Attributes
« Reply #1 on: January 23, 2003, 03:00:51 am »
Drop it to a class in a digram
Ian Turner
  • Crumbs Chief!
« Reply #2 on: January 23, 2003, 04:24:49 am »
Thanks!
One fairly insignificant side-effect I've noticed (when using the Enterprise product with Require User Lock To Edit enabled and a SQL Server back-end) is that the copied attribute or operation is locked-out by default even if the class you drop onto is not. You can then only delete the attribute or opertation through the class properties - not the Project Explorer...
Still, very trivial so who cares!
