Author Topic: Copying Messages between sequence diagrams  (Read 3698 times)
lenin
  • I love YaBB 1 Gold!
« on: February 24, 2003, 06:11:34 am »
  I am trying to find the best way to copy sections from a large sequence diagram to create a series of smaller ones. When I try copy / paste, the objects get copied but not the messages between them. When I export to XML and try to re-import into another package name to delete the bits I din't need I get "Package already exists...". I can clear this by checking "remove GUID" from the import box, but this looses the identity of the objects.
Does anyone have a workaround?
Tjerk
Re: Copying Messages between sequence diagrams
« Reply #1 on: February 24, 2003, 06:38:08 am »
Hi Lenin,
Is your sequence diagram really that large? If you already have your methods defined for your classes or components, then it shouldn't be so much work to redraw a part of a sequence diagram, I guess. The messagenames can then be selected from a list, including its parameters.
Sorry I don't have any solution.
Greetings and good luck,
Tjerk
