Author Topic: Bugs in 3.51.603  (Read 3790 times)
Tjerk
Bugs in 3.51.603
« on: February 26, 2003, 02:34:36 am »
I've found the following issues in build 603, but they probably are also in older versions:
  • The default Alt-T keyboard shortcut now opens the Tools menu, while the context menu of a class still mentions the Alt-T shortcut for attributes;
  • There is a defualt programming language for code generation, but there is no option to select the default for creating new elements;
  • The order of attributes in the projectbrowser is not the same as in the attribute editor (the latter being the same as shown in a diagram);
  • The order of attributes cannot be changed in the projectbrowser, would very much like that functionality;
  • The spellchecker shows that the evaluation version of the spellchecker library has expired!!! But it still works  :);
  • When a class is stereotyped as an interface, the class properties editorwindow doesn't show a tab for changing its methods;
These all are useability issues, but they become irritating slowly.
Greetings,
Tjerk
potterm
Re: Bugs in 3.51.603
« Reply #1 on: February 26, 2003, 05:00:01 am »
Here's another one...
  • The File menu fades up really s l o w ly when you click on it (takes about 2 seconds).  Easily fixed by selecting another menu animation method though...
