Author Topic: Controlling display of classes  (Read 2639 times)
fljmayer
  • I love YaBB 1 Gold!
« on: March 10, 2003, 07:56:32 am »
I have a class that has a constructor with about 10 string parameters. In a class diagram, that class's box is automatically made wide enough to display the constructor's entire parameter list, wasting a lot of space on the diagram. I tried to manually resize the class (make it smaller), but it jumps back to where it was. I looked for display options to disable the display of method parameters, but no luck. Is there any resolution?
Tjerk
Re: Controlling display of classes
« Reply #1 on: March 10, 2003, 08:17:38 am »
Hi Felix,
Try right-clicking the background of a diagram, select "Diagram properties...". A popup window comes up where in the lower right corner, you can select which parameter detail you would like to have on your diagram.
Greetings,
Tjerk
« Last Edit: March 10, 2003, 08:18:00 am by Tjerk »
