Author Topic: Problems moving requirements from DOORS to EA  (Read 3848 times)
sd
« on: March 18, 2003, 10:04:42 pm »
Hi!
DOORS can make almost any kind of file. Including .cvs.  In order to test this, I made an .cvs export, but there is no data ?? I selected a package where I saw a requirement, then I selected <edit/new> from Specification from .cvs, then selected fields : Requirement Difficulty, Requirement Priority, Name, GUID, Type. Then I pressed Save and then Run and View File, but it contained only headers. Similar problem with XML export – XML export process stays blank and the file is not created. I’d rather not to try import before I have made an export – I’d like to find out first the required syntax.
SD
PhilR
Re: Problems moving requirements from DOORS to EA
« Reply #1 on: March 19, 2003, 06:32:22 pm »
Make sure you have the "Export" option checked.  The default is "Import".
Works OK for me.
PhilR
