Author Topic: New Feature/Bug Fix Request  (Read 2593 times)
fwoolz
« on: April 06, 2003, 04:59:48 pm »
Hi All,
Here are a few feature requests and one bug fix request:
-- Both of these requests arise from difficulties I've had in arranging use cases inside of collaboration ovals ---
1. Use case & collaboration ovals: Should have independent vertical & horizontal resizing of use cases & collaborations (allow oval to have any eccentricity/aspect ratio).
2. Use case/collaboration label: should be able to move it from the center of the oval to wherever desired.
-- These are of a more functional nature, and are based on work I've done in trying to represent network messages between nodes in a distributed system ---
3. Sequence diagram messages: Need to be able to have ability to place messages between objects at exactly the same height (i.e., the same time).
4. Sequence diagrams messages: Add support for downward sloping messages to provide visual presentation of non-instantaneous messages.  NB: This is permitted by the UML standard.
-- This would help alleviate difficulties dealing with many objects on a single diagram --
5. Sequence diagram messages: Add “off-diagram” reference to linked sequence diagrams.
-- This is a minor annoyance, but it would be nice to have it fixed! --
6. Code generation: Fix problem where initial value of an attribute isn’t reflected in code, and initial value in code doesn’t show up after synching model.
Cheers & Thanks,
Fred Woolsey
Fred Woolsey
Interfleet Technology Inc.
