Author Topic: VB.NET attribute with Single Quote  (Read 3433 times)
Italstudio
  • I love YaBB 1 Gold!
« on: March 06, 2003, 07:30:47 am »
Hy,
When I execute "import directory structure" of a VB.NET project that contains a class
with the following property:
<Description("Determina se il testo all'interno del controllo può essere modificato oppure no"), _
Category("ItsExtended")> _
Public Property [ReadOnly]() As Boolean
End Property
I obtain the following error:
DAO.Database [3075]
Syntax error (missing operator) in query expression ...
The cause of the problem is the presence of the single quote (') inside of the description.
EmmaN
  • Sparx Support
Re: VB.NET attribute with Single Quote
« Reply #1 on: April 07, 2003, 06:13:40 pm »
Hi
Have you tried this workaround? Substitute the single quote for the ASCII equivalent: Chr(39). So your description string would become:
"Determina se il testo all" & Chr(39) & "interno del controllo può essere modificato oppure no"
It's worth a try...
