Author Topic: Using Sequence Diagrams - Best Practices  (Read 3934 times)
kevinimnotspacey
  • not spacey, well... sometimes.
« on: April 24, 2003, 11:30:43 am »
Hello!
We like to go through the process from use case to sequence diagram to class diagrams.  It seems like EA should support this with ease.  It should be able to create a set of classes from a set of sequence diagrams right?
Also I'm not sure if we're using the application correctly, we create a single diagram, and would like to copy diagrams around, but then the object instances get really messy... Can someone provide a method to the madness? How do you layout your diagrams in packages so they are nice and easy to find and lookfor.  Also do you copy diagrams at all?  Any hints out there to using Sequence Diagrams correctly? (i.e. drag from the toolbar, don't drag existing instances onto multiple diagrams, etc...)
Thanks!
:: ! spacey ::
