Author Topic: Code Generation / Export Requirement or ToDo Text  (Read 3404 times)
Elmi
« on: November 14, 2006, 01:00:23 am »
Hello
I am using the code generation templates.
They also create class headers.
The class header contain items like \todo xyz  (Doxygen tag)
Successfully I use \brief    :  %opNotes%  to export the classes description.
Similar to this I need a way of adding the todo-text in EAand then exporting it behind the \todo item.
I thought about adding the todo item as a requirement (requirement tab in the class dialog). But I can not find any way to export this text to my generated code.
Anyone have any idea on how to create todo items with the generated code ?
« Last Edit: November 14, 2006, 01:02:00 am by Elmi »
Re: Code Generation / Export Requirement or ToDo T
« Reply #1 on: November 14, 2006, 05:41:09 am »
Don't know off hand.
There's been a lot of discussion of Doxygen type tags in the forum (several sections). Try searching on Doxygen; perhaps something in these discussions will get you where you want to go.
If you do get this solved, please post the solution.
kenneth.nielsen
  • just a dude
« Reply #2 on: February 22, 2007, 12:32:47 am »
write a \todo in you ea comments
