Author Topic: Typos in the help manual...  (Read 3365 times)
Havyck
  • Cry havoc, and let slip the dogs of war...
« on: April 25, 2003, 05:42:46 pm »
This is not meant as a criticism, just a heads up. I'm reading through the help manual and there are quite a few typos. I'll just post them as I find them and hopefully they will be corrected in future versions...We have to create a help manual for our project here at the lab so I can sympathize! ;)
Under Event
The second element is the ['Send Event'. this] element...
Under General Settings
Tag   A free text area [that is may be filtered]in Use Case [Metric s and] Search dialogs - typically used for keywords, context information etc.
Under Using Classifiers
Note that in the message dialog you [may also elect to include message defined] in the target classifiers inheritance hierarchy.
Under New Elements
Check the Open Property Dialog [is you what the] main property sheet to open immediately after the element is created
Under Copying Attributes and Operations between Elements
Open a diagram with the target element in it [(in the example below, the AccountItem class is the target and Customer element is the donor]
Under Operation Parameters
Note: In diagrams, you can set the [amoutn] of parameter detail that show using the
Under Override Parent Operations
[It is also to configure] this dialog to show every time you add a Generalization or Realization link between [classes and their are] possible operations/interfaces
« Last Edit: April 25, 2003, 08:30:45 pm by Havyck »
EmmaN
  • Sparx Support
Re: Typos in the help manual...
« Reply #1 on: April 27, 2003, 11:33:08 pm »
Hi Havyck
Thanks for letting us know about these typos. We'll have them fixed as soon as we can.
Emma  ;)
admin
« Reply #2 on: May 04, 2003, 11:08:35 pm »
Hi Havyck
Actually we are currently having our Helpfiles rebuilt, so hopefully most of these errors will be rectified during this process.
« Last Edit: May 04, 2003, 11:30:16 pm by Newman »
