Author Topic: Scripts for MySQL repository?  (Read 2809 times)
detayls
  • UML - sounds like a form of paint....
« on: May 05, 2003, 10:22:11 pm »
The help system states:
"To create a new MySQL repository, you will need to first create a database into which you will import the table definitions for EA. Sparx Systems provide a suitable SQL script to create the required tables - how you create the database and execute that script are up to you. " under "Create a New MySQL Repository (Corporate Edition only)"
Where are the suitable SQL scripts?  ???
Thanks.
Detayls
Tjerk
Re: Scripts for MySQL repository?
« Reply #1 on: May 06, 2003, 12:55:59 am »
Hi David,
You will find those scripts on the Sparx homepage under Registered User, login with the details you've got when you bought EA and select Corporate Edition.
The page with the proper downloads will come up.
Greetings,
Tjerk
