Author Topic: problem with exec_add_in macro  (Read 5365 times)
amirarismore
« on: February 28, 2007, 10:06:56 am »
I try to use
name=%qt%%EXEC_ADD_IN("CS_AddinTaggedCSV","SuperTest","kjbk")%%qt%
in my transformation template but it doesn't work. the result is name="". If i try name=%qt%%EXEC_ADD_IN()%%qt% I have the same result and no error.
My addins menu work, my EA_Connect work:
[size=10]namespace CS_AddinTaggedCSV
   public class CS_AddinTaggedCSV
public string filecontents = "";
public bool readline = false;
private bool m_ShowFullMenus = false;
public Form1 theForm;
       public object SuperTest(EA.Repository Repository, object ggcfcg)
           // create a writer and open the file
TextWriter tw = new StreamWriter("c:\\log.csv");
// write a line of text to the file
tw.WriteLine("test");
// close the stream
tw.Close();
           return "Coucou";
//Called Before EA starts to check Add-In Exists
public String EA_Connect(EA.Repository Repository)
           System.Windows.Forms.MessageBox.Show("cava?"); // This works
           return "";
//Called when user Click Add-Ins Menu item from within EA.
//Populates the Menu with our desired selections.
public object EA_GetMenuItems(EA.Repository Repository, string Location, string MenuName)
//EA.Package aPackage = Repository.GetTreeSelectedPackage();
switch( MenuName )
case "":
return "-&CS AddinTaggedCSV";
case "-&CS AddinTaggedCSV":
string[] ar = { "&Tagged CSV Export", "", "About..." };
return ar;
return "";
//Sets the state of the menu depending if there is an active project or not
bool IsProjectOpen(EA.Repository Repository)
try
EA.Collection c = Repository.Models;
return true;
catch
return false;
//Called once Menu has been opened to see what menu items are active.
public void EA_GetMenuState(EA.Repository Repository, string Location, string MenuName, string ItemName, ref bool IsEnabled, ref bool IsChecked)
if( IsProjectOpen(Repository) )
if( ItemName == "&Tagged CSV Export" )
IsChecked = m_ShowFullMenus;
else if( ItemName == "Menu2")
IsEnabled = m_ShowFullMenus;
else
// If no open project, disable all menu options
IsEnabled = false;
//Called when user makes a selection in the menu.
//This is your main exit point to the rest of your Add-in
public void EA_MenuClick(EA.Repository Repository, string Location, string MenuName, string ItemName)
switch( ItemName )
case "&Tagged CSV Export":
String writerString;
String tagString;
tagString = "";
writerString = "";
EA.Package aPackage;
foreach(EA.Package thePackage in aPackage.Packages)
writerString = writerString + thePackage.Name.ToString() + "," + thePackage.ObjectType.ToString() + "\n";
//MessageBox.Show(writerString);
foreach(EA.Element theElements in thePackage.Elements)
foreach(EA.TaggedValue theTags in theElements.TaggedValues)
tagString = tagString + theTags.Name.ToString() + "," + theTags.Value.ToString() + ",";
writerString = writerString + theElements.Name.ToString() + "," + theElements.ObjectType.ToString() + "," + tagString + "\n";
tagString = "";
foreach(EA.Element theElements in aPackage.Elements)
writerString = writerString + theElements.Name.ToString() + "," + theElements.ObjectType.ToString() + "," + tagString;
tagString = "";
TextWriter tw = new StreamWriter(aPackage.Name.ToString() + ".csv");
tw.WriteLine(writerString);
// close the stream
tw.Close();
break;
case "&Menu2":
break;
case "About...":
Form1 anAbout = new Form1();
anAbout.ShowDialog();
break;
public bool readLine(StreamReader sreader)
bool answer;
answer = false;
try
filecontents = filecontents + "\n" + sreader.ReadLine();
catch
answer = true;
return answer;
}[/size]
please, help meeeee!
Re: problem with exec_add_in macro
« Reply #1 on: February 28, 2007, 02:23:55 pm »
Well, I would suggest that you method isn't being called at all because the add-in identification is wrong.
Make sure that the first parameter corresponds to the name of the registry key identifying you addin for EA.  (See http://www.sparxsystems.com/EAUserGuide/index.html?deployingaddins.htm)
