Author Topic: XSD Export Crash  (Read 4670 times)
saschwarz
XSD Export Crash
« on: May 26, 2003, 09:15:13 pm »
Hi
I'm using the EAExample project with the latest EA 3.51 Professional build (eval) to try out XMLSchema export. I've found two things:
1. For a package if you specify any file location other than the default directory the process fails with no error message and no observable action. Since the DTD must be present in the directory during generation there doesn't appear to be a reason for allowing the user to select a different output directory...
2. When exporting "Logical View|Class Model" EA crashes when(after?) the status line indicates Diagram:Orders. The options selected in the export dialog are: Export Diagram, Write Log File, Use DTD. The dialog that comes up is "Runtime Error". I've tried a few other selections in the export dialog and they all seem to crash. I'm using Win XP.
Steve
