Author Topic: Saving/exporting Matrix profiles?  (Read 17131 times)
dmf
« on: March 01, 2007, 04:19:13 pm »
I want to be able to export my Matrix profiles for others to use - any idea how?
Re: Saving/exporting Matrix profiles?
« Reply #1 on: March 01, 2007, 06:26:36 pm »
It's a bit hard to do, as it is bound to a particular model.  However, from memory if you have a hyperlink to a matrix profile (http://www.sparxsystems.com.au/EAUserGuide/index.html?hyperlinks.htm) in a package being exported to xmi, the matrix profile will also be copied.
« Reply #2 on: March 02, 2007, 06:46:53 am »
Simon,
Could this be (easily) incorporated as a Reference Data category?
« Reply #3 on: March 02, 2007, 12:30:29 pm »
Simon,
Seconded!
« Reply #4 on: March 04, 2007, 01:01:01 pm »
No, it can't be incorporated into reference data because it is dependant on individual package ids.  Even if you did export it and import it into another model it wouldn't work.
dmf
« Reply #5 on: March 04, 2007, 01:28:57 pm »
We are actually using EA in an environment whereby multiple developers are working locally to their machine on the same model data, being managed within a subversion repository.
I tried saving hyperlinks in a drawing & transferring to others via xml.  Did not seem to work initially.  I'll keep trying.
« Reply #6 on: March 04, 2007, 02:25:31 pm »
Simon,
I suspected as much - but how about exporting the GUIDs (at worst) and the underlying query at best?
« Reply #7 on: March 04, 2007, 06:59:37 pm »
Currently the reference data does not reference model data (eg. Packages) in any way.
In theory this could be extended handle mapping between guids and ids of a package.  The underlying query isn't complete without the packages being specified in some manner.  As a result, in my opinion this information would fit better with the XMI.
Keith Slarke
« Reply #8 on: August 02, 2022, 11:41:47 pm »
I am using the V 15.2.1599 and the relationship matrix Profiles are not being saved when the model is copied to another diagram for backup.
The relationships are copied and are correct in the copy version.
It is just the profiles that is not copied across and that does not require any GUID or project specific data just the package names.
I have tried exporting in a CSV and that does not contain the profiles either.
