Author Topic: C#, attributes, and reverse engineering  (Read 4306 times)
neutronic
  • I love YaBB 1 Gold!
« on: June 02, 2003, 10:00:39 am »
I have stumbled accross an interesting thing.
In my current project we are using Enterprise Services in DotNet and C#.
When I got to reverse engineer my C# code,  EA does not pick up the class, that is sprinkled with Enterprise Services attributes.
Code bit:
[System.EnterpriseServices.Transaction(TransactionOption.NotSupported, Isolation=TransactionIsolationLevel.Serializable, Timeout=30)]
     [ComponentAccessControl]      // Enable object level acess checks
     [SecureMethod]                        // Enable Method level access checks
     public class MyServicedComponent : ServicedComponent
[SecurityRole("PrivateFunction")]
           public System.Data.DataTable GetStuff(int id)
                          return null;
Is this a known thing, or am I doing something wrong?
EA simply does not reverse engineer it as C#, and when using the Java tool, it does create a class but the attributes become the method if I remember correctly.
It would be awsome if somebody could tell me how to get around this, short of removing all the attributes.
DMT
Re: C#, attributes, and reverse engineering
« Reply #1 on: June 03, 2003, 05:30:26 pm »
It would be nice to know if there is any support for FORWARD engineering of c# attributes as well...of if it's planned, perhaps using tagged values.
benc
« Reply #2 on: June 03, 2003, 07:01:14 pm »
Hi Neutronic,
Using your sample code (and inserting the missing open and close braces {}, for the class), I was unable to replicate the error.  I was using Build 611 on XP.
The class was created, though the attributes were omitted (the ability to import the attributes is a planned addition to EA).  Perhaps there's a step I'm missing in trying to reproduce the error .. let me know.
DMT: Forward engineering C# attributes will soon be a possibility with code generation templates.  Yes, attributes will be represented using tagged values.  You will be able test for the existence of a particular tagged value and customize the code accordingly.
I hope this will prove useful.
Ben
neutronic
« Reply #3 on: June 04, 2003, 08:20:15 am »
Interesting I went back and made another attempt and again ti failed, but armed with your information I started removing and inserting bits of code in the file.
If I removed all the comments I found that the code was reverse engineered fine. Thus my original assumption was wrong.
I believe now, that the reason it was not reverse engineered was an inline comment in the "using"
section of the source code
Example:
using System.Runtime.InteropServices;      // This is only used to force the introp guid to be the one specified in the interface/class attribute
namespace MDCH.EnterprisePortal.Applications.LotStatusReport.BusinessObjects
     /// <summary>
     /// This is a Serviced component security wrapper for the  object.
     /// For comment on the
This is not a big deal and very easy to avoid :)
Thanks.
