Author Topic: Sequence diagram bug ?  (Read 5156 times)
Oscar
« on: June 05, 2003, 02:08:38 am »
I'm trial-testing EA version 3.5.614
I have a sequence diagram with 5 object and 10 messages.
After adding the tenth message I can't add any messages below the lowest message.
However I can add messages above.
Is this a bug ?
Grrr,
Oscar
Fintan
Re: Sequence diagram bug ?
« Reply #1 on: June 05, 2003, 04:39:29 am »
Hi Oscar,
The 5 objects on your sequence diagram should have  a "life line" attached (dashed vertical line).
If you click on any object and drag the bottom handle this will extend the life line of the objects downwards.  You should now be able to add messages below your last one.
Fintan
Oscar
« Reply #2 on: June 05, 2003, 04:59:16 am »
Thanks Fintan
Oscar
