Author Topic: EA and Struts  (Read 3116 times)
darryl_staflund
  • "mmmMMMmmm!!!   UML!"  -- Attributed to Homer
EA and Struts
« on: June 13, 2003, 08:27:10 am »
Hi there,
I was wondering if anyone out there has suggestions on how to use EA to implement traceability in a Jakarta Struts application in the following way:
1.  Between Java classes, JSP pages, and the action elements declared in the 'struts-config.xml' file?
2.  Between Java classes, JSP pages, and the Tiles definitions declared in the 'tiles-defs.xml' file?
3.  Between Java classes, JSP pages, and the dynamic form beans defined in the 'struts-config.xml' file?
4.  Between Java classes, JSP pages, and the validator rules defined in the validator-defs.xml' file?
As you have no doubt noticed, there is a common theme running through all my questions, i.e. how do you establish traceability between physical class files and objects created dynamically at runtime from declarations provided in bits and pieces of XML files?  And, in a related question, how do you establish traceability between two or more objects created dynamically at runtime from declarations provided in one or more configuration files?
Thanks for your help and suggestions.
Darryl Staflund
