Author Topic: Error Loading existing project  (Read 3660 times)
Bey
« on: June 09, 2003, 05:55:56 pm »
We just bought a few licenses of the professional edition and our team has been modifying a project on the network.  We have done some significant amount of work on it just this past week and today we get an error:
Fatal error:  Unreconizable  database format "filename.EAP"
What's up?!?!?  Please don't tell me we lost all our work!   :'( :'(
Tjerk
Re: Error Loading existing project
« Reply #1 on: June 10, 2003, 12:28:21 am »
Hi Bey,
Have you tried "Repair database"? It's a menu option available in EA. Sometimes a flag gets corrupted by the JET3/4 database engine (from Microsoft, not Sparx), that menu option repairs the database.
I'm not sure if this error is also given with an older database / repository design. If the version you previously built your EAP file with is a couple of month old, it could be that the EAP file needs to be upgraded to the new repository design.
Greetings,
Tjerk
zack2
« Reply #2 on: June 16, 2003, 11:19:08 am »
Another problem might be your database version. We get this error message when we try to open an Access 2000-based project without setting the "Use JET 4.0" option. Give this a try.
You have to open the sample program, then click on the View/Options menu selection, then check the "Use JET 4.0" checkbox option. This will require you to restart, then you should be able to open your project.
