Author Topic: Directed associations in EA  (Read 6372 times)
jojooo
« on: June 18, 2003, 01:15:31 am »
I spent several hours on finding a solution to this problem but had no success. Specifically: How can I display directed associations in EA, i.e., association lines having an arrow at one end in a class diagram?
A (dirty) work-around is to create a dependency between two classes and then change the relation type to association. It works, Unfortunately I did not find a menu that enables me to generate this arrow directly on an existing association.
Any hint?
Thanks in advance,
--Joachim
Tjerk
Re: Directed associations in EA
« Reply #1 on: June 18, 2003, 01:29:14 am »
Hi Joachim,
Try right clicking the assosiation, select association properties and select source to target direction.
Greetings,
Tjerk
jojooo
« Reply #2 on: June 18, 2003, 04:45:28 am »
Hi Joachim,
Did work. I was (almost) absolutely sure that I tried this before, don't know what went wrong. Thanks again.
--Joachim
